3
This discussion topic has been answered Discussion topic: How to change SKY hub encryption
This message was authored by: Derek0676
The encryption on my SKY hub is WPA2-PSK and it should be WPA2-AES or WPA3. How do I change it please.
Re: How to change SKY hub encryption
@Derek0676
Only the white Max Hub is capable of WPA3
@Derek0676
Avatar for Derek0676
Thanks for the response.
@Derek0676 you will find the vast majority if routers use WPA2-PSK as you need new chips to support WPA-3 which is practice are only in devices and routers designed in the last couple of years. One of the regular issues we see with the white WiFi Max hub on the forum is devices not being compatable with the default WPA3-T - the T is for transition - setting on those hubs which is designed to be compatable with older silicon let alone true WPA3..
