Discussion topic: How long does a internet upgrade take to work
This message was authored by: Sophgibb
I upgraded my super fast broadband to ultra. I am wondering how long it takes for it to work?
Re: How long does a internet upgrade take to work
@Sophgibb
When is your ultrafast activation date?
Do you have a standard openreach mastersocket or an openreach ont
Avatar for Sophgibb
Level 0 icon
Hi, it said activation date if for today.
I believe I have the openreach ont
@Sophgibb
Ah , so its an upgrade of speed using the same equipment rather than a brand new full fibre connection.  I would have hoped it would be almost instantaneous or at the most 1/2 hour.  But you may have to wait until just before midnight tonight. What lights are on the ont ? And what speeds are you getting
Avatar for Sophgibb
Level 0 icon
Yeah just speed.
yeah the lights are on and currently just 74mbps with the original speed
@Sophgibb
Get back to us tomorrow first thing if you haven't been upgraded by the morning
Could i ask you to post your router stats just to make sure
