Discussion topic: How do I connect my new hub?
Message posted on
17 Apr 2024
01:21 PM
- last edited:
17 Apr 2024
01:27 PM
by
Kelsingra
Hello I have received my new broadband hub in post today and I'm just looking to know do I connect it to my old connection box that fibrus set up?
Moderator note: Changed title to reflect topic more.
Message posted on 17 Apr 2024 01:39 PM
Re: How do I connect my new hub?
Fibrus is a seperate network primarily working on rural fibre in northern ireland
What connection are you getting from sky
When is your activation date
Message posted on 17 Apr 2024 02:02 PM - last edited: 17 Apr 2024 02:03 PM
Almost certainly not: Sky uses the Openreach network (in the UK) rather than optical cable from any altnet.
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Message posted on 17 Apr 2024 04:39 PM
Message posted on 17 Apr 2024 04:44 PM
Sky doesn't use fibrus . If you are getting sky fttp then sky will contact openreach to install an openreach fibre modem ont
Could you follow @TimmyBGood link and post the table and notes after removing your address from the image
Message posted on 17 Apr 2024 04:49 PM - last edited: 17 Apr 2024 04:54 PM
Presumably a whole new optical drop cable too, from the nearest Openreach CBT, plus a new CSP and optical pigtail to the ONT. As far as I'm aware none of the Fibrus infrastructure could be used by Sky or any other Openreach ISP.
