Discussion topic: How do I call sky
Message posted on 07 Sep 2025 09:11 AM
How do I call sky
There is no number displayed on the contact us section for me to be able to call, I don't have a sky landline or phone so I can't use the 150 number what do I do?
Message posted on 07 Sep 2025 10:05 AM
Re: How do I call sky
What is the issue with your broadband, can we help you via here ?
Message posted on 07 Sep 2025 10:21 AM
As asked by @caesarome is it something we can help with to save you having to make contact?
You have a Sky Talk subscription but have chosen not to plug in a phone handset which is fine but would be the easiest way of getting through.
Not including phoning these are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others)
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
