Discussion topic: Broadband intermittent problems
This message was authored by: BradSol
Been with Sky fibre150 broadband for 2 weeks now. I seem to be off line more than on line with the new service. My previous service provider was slow speeds but now I'm just not getting connected to the net. Anyone else with similar problems
Re: Broadband intermittent problems
@BradSol
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
