Discussion topic: High packet loss and ping, low upload
Message posted on 23 Jun 2024 10:19 AM
I have been getting very high packet loss (AVG 60) and high ping (300-3000) for the last week, with very low upload (0.3) but when running check my connection on sky it says it's fine? Its started since last Sunday when sky broadband had gone down in the area and not been the same since! I have restarted the modem multiple times and it's not got any better, it's the same on WiFi and ethernet.
Message posted on 23 Jun 2024 10:35 AM
Re: High packet loss and ping, low upload
Trying to play any games or load any websites is extremly fustrating, here are some of the logs from the modem.
having issues uploading sys log text as its saying its spam.
Message posted on 23 Jun 2024 10:48 AM
As you can see from both images the internet has been terrible since the 18th
Message posted on 24 Jun 2024 09:58 AM
if there any more logs needed let me know
Message posted on 25 Jun 2024 11:47 AM
There is a clear fault as your upload speed should not be 400kbps on an FTTC line with 30+mbps download. You may want to call to report the fault, however I have escalated your post to chat with a Sky rep, look out for a message on the forum.
Message posted on 25 Jun 2024 12:33 PM
Thanks for escalating this. We’ve sent an invite to @SteveBransden to chat.
Message posted on 27 Jun 2024 11:54 AM
We are still looking to help you @SteveBransden . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Message posted on 27 Jun 2024 12:54 PM - last edited: 27 Jun 2024 12:57 PM
Because the speed is so poor and varies a great deal in both directions, I estimate that the fault is near the premises and most likely is overhead cable on a pole is a poor joint, recommend Openreach look at the pole outside the premises. The drop wire from pole maybe damaged beyond repair at pole end and need replacing.
