Discussion topic: High Latency and jitter
This message was authored by: Defiance
My connnection is getting gradually worse, now online gaming is playerable
Uising https://speed.cloudflare.com/ My latence and jitter and 30+
Any suggestions
Avatar for Defiance
Re: High Latency and jitter
Reply from 8.8.8.8: bytes=32 time=13ms TTL=116
Reply from 8.8.8.8: bytes=32 time=17ms TTL=116
Reply from 8.8.8.8: bytes=32 time=14ms TTL=116
Reply from 8.8.8.8: bytes=32 time=2433ms TTL=116
Reply from 8.8.8.8: bytes=32 time=16ms TTL=116
Reply from 8.8.8.8: bytes=32 time=12ms TTL=116
Reply from 8.8.8.8: bytes=32 time=79ms TTL=116
Avatar for Defiance
Avatar for Defiance
This wired and wireless across devices
@Defiance
Realistically I suspect there's nothing there which any ISP would consider investigating.
While Sky rather unfortunately use the generic 'Ideal for gaming' slogan to promote their fibre broadband, it doesn't actually come with any service level guarantee for latency or jitter at all: this is essentially the same for all such internet connections from any provider.
Avatar for Defiance
I would agree, Sky believe in crapper.
There internet has been **bleep** since i moved, can't wait to leave.
