Discussion topic: Hi, I’m having Xbox Live connectivity issues. My Xbox does not receive an IPv4 address on Sky Broadb
This message was authored by: Geldhsje
My Xbox is not working with skys ipv6 Ds lite and I need to change it to Dual stack Ipv4
Re: Hi, I’m having Xbox Live connectivity issues. My Xbox does not receive an IPv4 address on Sky Br
@Geldhsje What sky hub are you using?
This message was authored by: -rpnz-
Posted by a Sky employee
Hi @Geldhsje
Sky does not use DS-Lite; all our broadband services are dual-stack enabled with both native IPv4 and IPv6, however if you have a Sky Max Hub, or the latest Sky Gigafast+ Hub , or another MAP-T-capable CPE router, you will get MAP-T instead.
None of the above, however, should prevent your XBox from getting a private IPv4 address—this would instead suggest that there's a problem within your home network.   If your XBox is getting an IPv4 address but you're having connetivity issues whilst playing games/voice chat etc., make sure you have enabled UPnP on the Sky Hub.
