Discussion topic: Problem with inside line
This message was authored by: Rachel80
Router is showing orange light
Re: Problem with inside line
@Rachel80
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
