Discussion topic: Help
This message was authored by: Snowysam
Help
We have an amber light which has stayed on. We have tried all that was suggested.
Re: Help
@Snowysam
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
