Discussion topic: Help
This message was authored by: Christine181
Help
WIFI not working
Re: Help
@Christine181
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: Help
@Christine181
No need to keep repeating the same question. I've replied to it. The duplicates have been removed.
