Discussion topic: Help
Message posted on 20 Sep 2025 02:52 PM
Help
Need WiFi to work p
Message posted on 20 Sep 2025 02:59 PM
Re: Help
@Mandygelliott
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
Message posted on 20 Sep 2025 03:00 PM
Re: Help
@Mandygelliott Start by looking at this link, your post has nothing to go on!
