Discussion topic: Help
This message was authored by: Wucki
Help
I would like to speak to  technical please
Re: Help
@Wucki If you go to the top off the page the About explains to you all about the Forum. The link below will give you the number, just see need more help.
https://www.sky.com/help/home
This message was authored by: peter-marlow+1966
Re: Help
Call sky and once  the automated message system says we have sent you a link would you like to use it say no and you will get to talk to an advisor hopefully you will get your problem sorted
P c marlow
