Discussion topic: Help with the socker
This message was authored by Sorina This message was authored by: Sorina
Help with my socker i canot plug in the black cabel only the grey one
Re: Help with the socker
@Sorina
If you only have one socket on the mastersocket you may have to buy a microfilter.
Can you post a photo of the mastersocket
@Sorina
Or identify it below
Sorina
Sorina
The black cabel is not going in becouse the cabel is small
Sorina
Where can i buy one from
@Sorina
Unless there's another socket at the address with a prefiltered faceplate (two ports) you'll need to source a plug-in microfilter: widely available online, in hardware stores or even charity shops.
@Sorina
You need a microfilter which can be purchased from dixons, currys. Pc world etc for a few pounds
Sorina
Ok
