Discussion topic: Help with new router not connecting to work network
Message posted on 01 Oct 2025 10:50 AM
Help!
We've had a new account for the house using a sky router and now I cannot connect to my work laptop (NHS). My IT dept says it's due to sky VPN but sky say it's working fine their end.
I can't get into anything in the network and I don't know what else to do. I've spent ages on the phone!
I've got a black hub if that helps!?
Message posted on 01 Oct 2025 11:08 AM
Re: Help with new router not connecting to work network
@spoonk Does the laptop connect to the sky Hub and normal browsing work, if your laptop also has an Ethernet port have you tried connecting with a cable?
Message posted on 01 Oct 2025 11:28 AM
Thanks for replying!
It works normal browsing absolutely fine it's anything that is work related won't work because I can't get into the network.
I tried via the Ethernet cable directly into laptop and then it tells that I don't have any internet connect 🤔
Message posted on 01 Oct 2025 11:37 AM
Hi @spoonk
Have you tried disabling Sky Shield in the app settings?
Message posted on 01 Oct 2025 11:45 AM
Yep, that has been turned off completely on Monday and still not luck.
the only difference from Friday to Monday was a new line set up in my name with the new router.
Message posted on 01 Oct 2025 11:49 AM - last edited: 01 Oct 2025 11:50 AM
@spoonk What new sky Hub, if the sky max the white one have you looked at the pinned post about VPN through the MAP-T system?
Having problems with a 3rd party VPN and have a Hu... | Sky Community
Message posted on 01 Oct 2025 11:52 AM
Yea my question would be is it a different hub to the one you had before
Message posted on 01 Oct 2025 12:08 PM
They are both the black ones just they sent a new one and set up the new line.
thanks so much both of you for replying! I could cry!
Message posted on 01 Oct 2025 01:48 PM
That is quite odd then. Have you tried completely resetting the hub? Hold the reset button on the rear for 30 seconds minimum
Message posted on 01 Oct 2025 01:56 PM
@spoonk Getting very confusing now, see the hub link and say what before to what now from the pictures, the old SR203 Sky Broadband Hub is normally a very rock solid on any connection and no real issues!
