Discussion topic: Help please
This message was authored by: humptydumpty1234
Help please
Only 2 green lights on router router has been turned off and back on  still no joy
done a service checker no issues according to that
no connection to phone or tvs
Re: Help please
@humptydumpty1234
___________________
You posted just after midnight. If this started since midnight be aware that any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
