Discussion topic: Hbb isn't working
This message was authored by: Lauren__
Message posted on 01 May 2026 08:24 PM
Hbb isn't working
Wifi isn't working Hub display 2 amber lights. 2nd and 4th. Reset router many times
Find out more
Message posted on 01 May 2026 09:47 PM
Re: Hbb isn't working
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
