Discussion topic: Having constant outages
Message posted on 30 May 2025 10:46 PM
I'm having issues with my broadband as of this week I've been suffering with outages I've had four this week and I not sure on what's causing this. It's been putting me behind work is there anyway you can help me out with this issue I'm facing.
Message posted on 31 May 2025 05:23 AM
Re: Having constant outages
@Morgan1999
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
