7
This discussion topic has been answered Discussion topic: Have no network connection
This message was authored by: Lash2
Have internet on all devices but can only watch normal tv as screen states no network connection. I have followed instructions to reset but no good
Re: Have no network connection
@Lash2 if other devices connect to the hub but the TV doesn't check the network settings on the TV. Assuming there is a wifi connection then check the TV has an IP address in the range 192.168.0.2 to 192.168.0.254 if it hasn't try resetting the TV to get the settings from the router.
My own TV kit was giving similar issues last weekend which were cured by a full reboot of the hub. It wasn't obvious what was causingbthe fault but there is a reason why every tech support script contains the request first the user reboots every bit of kit as often it clears obscure faults. When rebooting a TV disconnect the power until the power led goes out as otherwise the menory is not cleared.
@Lash2
Can you access the internet on other devices like phones and tablets ?
This message was authored by: KathyJ
Yes I have Internet on my laptop
This message was authored by: PatStoneham
A hub was put in today now I have no  network connection. I have followed all in structuin. I need help. I have rung sky no answer after 33 minutes
This message was authored by: laptop
Setting screen says unsuccessful connection you might need to connect a Sky Q booster.
network was fine until changing fibre 100 to WiFi Max.
This message was authored by: raymond+noble
Mines doing the same tried everything reboot Q and router and tried via password input all the same refused connection... so I've sky channels but nothing else can't do catch up etc etc no apps ... but everything else connected WiFi on phones iPad etc I'm thinking only solution is an engineer next ?
