Discussion topic: Have a LOS red light
Message posted on 19 May 2025 07:27 PM
I have a LOS red light on open reach box connecting to Sky Q router. How do I report to any
Message posted on 19 May 2025 07:33 PM
Re: Have a LOS red light
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 19 May 2025 07:36 PM
I have already done the tests and nothing is doing!! So I need to report it to Sky then. Is there a number I can call?
Message posted on 19 May 2025 08:00 PM
This might be useful to people… As far as an Openreach ONT goes:
POWER LIGHT: Steady green is normal; flashing is f/ware update.
PON LIGHT: Steady green...normal; flashing green....most likely connected but not authenticating, (an account problem, serial number mismatch etc.) (NB This could also be a whole range of other problems but authentication errors are most common); red light....no logical connection, i.e. fibre is lit but no sync.
LAN or PORT LIGHT: Green means a connection to the router; flashing is it passing data.
ALARM or LOS LIGHT: Unlit...normal; red light...loss of physical connection, i.e. unlit/broken fibre, equipment failure. Power cut at the other end etc.
Message posted on 19 May 2025 08:03 PM
150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
Try saying nothing when spoken to by the bot.
Message posted on 19 May 2025 08:18 PM
Thanks. I have managed to speak to Sky and reported the fault. So they checked and it is a fault in the area outside the house. So they have logged it and an Openreach engineer will arrange in the next 2 to 3 days.
