3
This discussion topic has been answered Discussion topic: HTTPS Only enabled
This message was authored by: Shazzy+Dee
HTTPS Only enabled
I have today moved to sky broadband from BT and now struggling to connect devices to the WiFi.
I am trying to connect my Bose smart speaker with Alexa but it keeps coming up with the message ' Safari can't open the page. The error was 'Navigation failed because the request was for HTTP URL with HTTPS-Only enabled'
Never had this problem on BT so what do I need to change in my settings either IOS or my Sky Max Hub?
Re: HTTPS Only enabled
@Shazzy+Dee
Some suggestions here:
https://discussions.apple.com/thread/255914488?sortBy=rank
@Shazzy+Dee
@Shazzy+Dee Since you have only just joined, would go look at your account, check the Broadband Shield product setting and turn it to off, you can always adjust it lower level later! Takes a few hours for it all to filter through!
Avatar for Shazzy+Dee
Thank you it's sorted it was a setting in safari but good info on the broadband shield as I wasn't aware this was there for settings adjustment.
