Discussion topic: HELP
Message posted on 08 May 2025 03:59 PM
HELP
Broadband keeps dropping
Message posted on 08 May 2025 04:04 PM
Re: HELP
@Broomer
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
