2
Discussion topic: Guaranteed minimum broadband speed
This message was authored by JonBoyJpk This message was authored by: JonBoyJpk
Can anyone tell me where in the sky app i can find where the guaranteed broadband speed is for my contract? It used to be easy to find but i cannot find it anywhere!  I just want to check what sky's minimum guaranteed speed is so i can compare to what mine actually is.  Please help. Thank you.
This message was authored by jamesn123 This message was authored by: jamesn123 Answer
Re: Guaranteed minimum broadband speed
@JonBoyJpk
If you run the line test in the My Sky app then tap where it shows 'Broadband' with your speed in a circle, then tap 'test my broadband', wait for that check to complete then scroll down and your minimum speed will be listed.
I am NOT a Sky Employee
@JonBoyJpk
JonBoyJpk
Thanks James. All good. Regards. Jonathan
