Discussion topic: Green flashing light
This message was authored by: Claire354
I've been waiting to speak to a sky technician for nearly 3 hours now - I've rebooted, reconnected etc numerous times - i suddenly lost connection for no discernible reason- no bad weather near me.
any help anywhere ? And why the wait ? - so frustrating - I need to work tomorrow -   Wry stressful
Re: Green flashing light
@Claire354
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Claire354 Hopefully you are aware sky customer service is 8am to 8pm also?
