Discussion topic: Green flashing light on hub
This message was authored by: Paulwedgbury
There is a green flashing light on my hub and I've lost all wifi
Avatar for Paulwedgbury
Level 0 icon
Re: Green flashing light on hub
Green flashing light on my hub and lost broadband
@Paulwedgbury Forum is not sky, posting goes no further than what you type! Run the service checker but it may just be way early if a fault is or has just happened!. Link to lights also below!.
