Discussion topic: Got constant white light on router
This message was authored by: j34999
Unplgged mains, used WPS, reset still no wifi
Re: Got constant white light on router
@j34999
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
