Discussion topic: Give up
Message posted on 01 Jan 2026 08:09 PM
Give up
Message posted on 01 Jan 2026 08:22 PM
Re: Give up
@Chris1705 If you dial 150 from your landline, you can have sky run a test to see if anything is shown to them, also the link below if you wish to do so yourself!
Try running the line test here to see if any faults are found:
