Discussion topic: Gaining access to hub
Message posted on 02 Jan 2026 11:56 AM
I need help gaining access to the admin side of my hub. A while back I changed my frequency from 5mhz to 2.4mhz. I now need to change this back but can't remember my log in details. Is there any way I can reset this so I can then gain access to the admin side of things and change it back. Any help will be greatly appreciated. For the record I'm using sky ultrafast.
Message posted on 02 Jan 2026 12:50 PM
Re: Gaining access to hub
@Darren2102 Does not matter if you are using ultrafast or not, if you do not know the password to the admin of the sky Hub then you are not getting into it, what hub are you using, the Tips above may help guide you!
