Discussion topic: Full fibre installation
This message was authored by: Claire50
I have an engineer booked for Monday for full fibre. When booked they said I don't need to be there. But online says they need access to a socket inside? I'm a little confused now. As I'm working when they are due. I've also been without WiFi for 3-4 weeks. So don't want it delayed any longer.
Re: Full fibre installation
@Claire50
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Avatar for Claire50
I tried that link but wouldn't do anything when I put in my address?
@Claire50 Link is working, you just need the house number and the post code entries filled...
Avatar for Claire50
@JimM1
I don't know what I'm doing wrong then. I put it in submit it goes round and round then stays at the address field.
Avatar for Claire50
@JimM1 @TimmyBGood is it to see if I have the full fibre thing in the house? I'm sorry not very technical minded. Because the only broadband I've had is through the phone line.
@Claire50 Yes, if you are in an area that is Fibre Ready, then there is NO Choice, OR Openreach if that is what you are getting will be coming to install a new cable from external to your home.... Two methods are OH Overhead off a pole, or underground duct....
Have linked my home picture, Now FF connected off the pole!
Current connectionCurrent connection
