11 Jun 2024 04:50 PM
11 Jun 2024 04:56 PM
Full fibre though sky, bt etc etc is up to openreach plans . . City fibre run their own network
If you wish you can enter you full postal address in the link below and post the table after removing your address from the image
11 Jun 2024 05:33 PM - last edited: 11 Jun 2024 05:39 PM
Sky, like BT/EE/Plusnet, TalkTalk and others use the national Openreach network, and can only provide FTTP where Openreach has deployed that technology. The target date for 80% coverage is December 2026.
As @cookiemonsteruk indicates, CityFibre and other altnet ISPs use private finance to lay their own infrastructure which only they have access to: this is typically in limited geographical areas with high population density.
If an altnet had coverage in your area then moving to them would be very reasonable decision: note that this isn't a 'switch' under the Ofcom regulated one-touch scheme though, and so you'd need to actually cancel with Sky.
