Discussion topic: Full fibre Gigafest
Message posted on ‎30 Mar 2025 01:30 PM
Full fibre Gigafest
I have just upgraded from SKY broadband superfast to full fibre gigafest.
The full fibre gigafest says I should be getting 900 mbps but I am only getting 76 mbps which is what I was getting with superfast.
Any suggestions would be appreciated.
Message posted on ‎30 Mar 2025 01:40 PM
Re: Full fibre Gigafest
What device are you measuring that speed on?
Are you using ethernet or wifi?
If etherneted what category cable are you using?
Message posted on ‎30 Mar 2025 01:45 PM - last edited: ‎30 Mar 2025 01:47 PM
And has the replacement of copper cabling to the address with optical fibre and an ONT actually taken place?
Message posted on ‎31 Mar 2025 12:30 PM
Thanks for the replies, got through to SKY, now getting 667mb/s.
Cheers.
