7
This discussion topic has been answered Discussion topic: Full Fibre equipment.
This message was authored by: Tony249
Hi. Wonder if anyone can help. I'm having full fibre broadband fitted and was expecting a parcel but all I received was a envelope with a wire in. Is that all I have to have delivered. Will the engineer bring everything else needed. Thanks
Re: Full Fibre equipment.
@Tony249 wrote:
Oh wow, was expecting a box with a bit more in than that.
As long as you already have a Sky Broadband Hub, it's all that is required.
Yes: that's the grandiosely named 'conversion kit' and enables a Sky Broadband Hub or Max Hub to connect with the Optical Network Terminal which the engineer will bring and install.
@Tony249 No that's it, will convert your existing sky Hub from the DSL port - Master Phone socket to the WAN connection and the new ONT for Fibre that will be fitted inside your home!
Use your time wisely now think were you need want the ONT to be installed, where your current hub is to what can go wrong if/when your hub get's put in the wrong position. Also take a look at the OR Install day video search to see that on google!
Avatar for Tony249
Oh wow, was expecting a box with a bit more in than that. Even managed to get it through the letter box. Thanks for your help.
Avatar for Tony249
Yes already have one of those, thanks.
This message was authored by: Nickcox2727
hope not as my phone point is about 10 metres further away from the hub
This message was authored by: Deb3000
@Nickcox2727  It's a standard cat 5e ethernet cable.  You can buy a 10m one easily enough.
