Discussion topic: Full Fibre No-Go
This message was authored by: AndyMac70
Full Fibre No-Go
I have just been informed by Sky that where I live (TN15 7..) we have finally had full fibre installed.
On trying to get it installed via Sky website all I get is ' Sorry, unable to proceed due to technical difficulties'
Has anyone had the same problem? Trying to get any useful advice and help from the 'virtual assistant' is frustrating and ultimately useless. To actually speak to a human being would be useful but if anyone has had this problem and has a solution would be grateful.
Re: Full Fibre No-Go
@AndyMac70 Are you trying to do it via your account and then see if the Upgrade is offered, what package do you also go for, there are issues at present with some HW being the Sky Max products?
Also try the OR Fibre checker just in case it is not them but the altnet?
Fibre Checker
