Discussion topic: Full Fibre Cable Installation
This message was authored by jm10 This message was authored by: jm10
I am switching to Sky and having full fibre installed at the weekend. Openreach have done their bit and the grey connection box is ready for the Sky Engineer.
Simple question:  I know the cable run must terminate near an electrical socket, but is there any limit to the distance of run  that is allowed from the Openreach box?
Re: Full Fibre Cable Installation
@jm10
Theoretically yes as Openreach specify a maximum of 10m worth of fibre run. However you could always try and sweet talk the engineer with tea & biscuits
I am NOT a Sky Employee
jm10
Thanks James -  I think 10m should do it but I'll make sure the kettle is on!   Regards, John
@jamesn123
jm10
Re: LANDLINE NOT WORKING
Hi, sorry to "piggyback" on this thread but.....
I transferred to Sky yesterday with a new fibre installation for broadband and talk. This was done at 1015 and the broadband is working fine. The phone is connected to the back of the hub but the engineer said it would take time to connect. At 1715, I had dialling tone but could not send or receive calls. I followed the online fault finding including switching the hub on and off. I then spoke with a sky call centre, who told me it could take 24 hours to work. It is now 1300 on Sunday and I have outgoing calls but still no incoming calls. Do I sit and wait or report it as a fault?
It appears that my problem is not unique, so I am disappointed as a new Sky customer, that I was not warned about the possible lengthy delays and what to do?     Regards, John
@jm10  Rather than piggy backing onto a different thread i've merged your latest post to your previous thread for continuity.
jm10
Sorry GD1, I'm new to this process!
@GD1
