Discussion topic: Frequent problem with wifi
Message posted on 06 May 2026 12:11 PM
we have problems with WiFi we get so often
can we have a sisit by your engineers so he can identify and solve the problem
Message posted on 06 May 2026 12:12 PM
Re: Frequent problem with wifi
What is the problem you are haing, do you have a weak signal in certain rooms or do you have no working broadband at all ?
Message posted on 06 May 2026 01:04 PM
The quality of the call especially What's up call are never consistent
can not hear the conversation
also in some too especially upstairs it gets cut off
some time our television gets broken pictures
Message posted on 06 May 2026 01:21 PM
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
