2
This discussion topic has been answered Discussion topic: French IP address
This message was authored by: Nick62
French IP address
Hi Since my broadband was set up I am showing up as my IP address being French, and as such I am getting French adverts on YouTube
This message was authored by: cookiemonsteruk Answer
Re: French IP address
@Nick62
If you go to the maintenence tab on your sky hub right at  the bottom you will see something like connectin status. Click on it and disable. Then after 1/2 enable again.  This should hopefully get you a uk public ip address
@Nick62
Avatar for Nick62
I confirm this has fixed the issue!
