Discussion topic: Force Desktop 5GHz Connection
Message posted on 04 Jan 2024 07:17 PM
I have the Sky Max Hub. My Desktop is connected to the 2.4GHz line, and I want it on the 5. I cannot see a way on the admin of separating my channels, and the channel selection is greyed out, so I cannot amend it to be lower than 149 so my desktop can connect. Has anyone managed to figure out how to do this on the Sky Max Hub?
Message posted on 04 Jan 2024 07:28 PM
Re: Force Desktop 5GHz Connection
As far as I know you can't split the frequencies on the Sky Max hub, only disable 5ghz. Your laptop should connect via 5ghz if its compatible and within a good enough range of the 5ghz signal. Keep in mind that just because your laptop may be showing a strong signal to your Sky hub, this may not mean you have a strong 5ghz signal to the laptop it may only be 2.4ghz that is reaching in that particular location.
Message posted on 04 Jan 2024 07:50 PM
If it is a modern laptop with windows 11 it will automatically connect at what the laptop thinks is the best connection
in my case 2.4ghz @130 mbps
if I want higher I turn off and back on the wireless adaptor and it switches to 5ghz @650 or 730 mbps
i have also found that starting high intensity activities like updating steam products will automatically swap it to the higher bandwidth
Message posted on 04 Jan 2024 08:39 PM
Does your desktop wifi adapter support 5G operation? If so then you maybe able to go the device adapter settings in windows, and force it to only operate in the 5GHz band.
