Discussion topic: Fibre
Message posted on 04 Feb 2026 03:48 PM
Fibre
Had this message from Sky
Openreach has identified that there is no capacity at the green cabinet on your street for a Fibre connection.
What does it mean?
Message posted on 04 Feb 2026 03:51 PM
Re: Fibre
This means that the local cabinet that supplies your street/area is full, as in there is no more slots to connect your line to. This can happen because Openreach usually doesnt deploy enough infrastructure to serve every single premises in the area because they assume there wont be a 100% uptake, or new homes are built.
Essentially you wont be able to order broadband until Openreach expand capacity in your area, or someone cancels their service and that slot becomes available.
Message posted on 04 Feb 2026 04:19 PM
Re: Fibre
Thanks, does this mean that any type of Broadband I purchase will result in the same outcome, or just Sky?
Message posted on 04 Feb 2026 04:25 PM
Re: Fibre
Any provider that uses Openreach infrastructure will result in the same outcome.
here are other providers that have their own infrastructure that might be able to provide you a service.
Message posted on 04 Feb 2026 04:46 PM
Re: Fibre
@AdamElliston You can also check for yourself the BTW status have a look use your address postcode details in the link!
Message posted on 05 Feb 2026 09:01 AM - last edited: 05 Feb 2026 09:02 AM
Re: Fibre
Cabinet capacity is specific to FTTC broadband from any Openreach client ISP.
ADSL is/was a direct connection with a telephone exchange, and FTTP uses a different topology.
