Discussion topic: Fibre upgrade drlivery
Message posted on 20 Oct 2025 05:37 PM
What should I have received in my parcel from Sky Broadband to be ready for Openreach to install full fibre?
Message posted on 20 Oct 2025 05:39 PM - last edited: 20 Oct 2025 05:56 PM
Re: Fibre upgrade drlivery
Potentially just an ethernet cable if you already have a Sky Broadband Hub (SR203) in use for Sky ADSL or FTTC and didn't choose to add the WiFi Max subscription supplement.
This comes as a surprise to many people.
Message posted on 20 Oct 2025 05:55 PM
New customers would typically receive a white Sky Max Hub, power supply and ethernet cable.
Message posted on 20 Oct 2025 07:51 PM
@MH94 If you happen to have an older sky hub or a sky Q hub, then sky may also update you to the Sky Broadband Hub at the same time as phone will now connect into the rear connection off the hub for digital landline!
