Discussion topic: Fibre put in. Dropping WiFi connection
Message posted on 09 Nov 2025 12:50 AM
Hello, I had fibre put in this week and it's made my connection worse and my WiFi keeps dropping out.
Message posted on 09 Nov 2025 07:57 AM
Re: Fibre put in. Dropping WiFi connection
@Ummar Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
