Discussion topic: Fibre install question
Message posted on 31 Oct 2025 01:05 AM
Currently have Sky broadband, Sky contacted me and set a date for a free fibre upgrade.
The sky hub is in my attic, connected to the phone line downstairs, have a network switch running network ports in all rooms and a decent AP downstairs.
Im concerned when then turn up they won't be able to set up the new equipment where I need it to be and will want to place it somewhere convenient for them. Anyone had experience with the engineers setting up where you ask?
I won't sign any work orders unless they can accommodate. Also, the neighbours have gone with another company and the wires on the front of the house are awful; they have made a bit of a mess of it, how flexible are the engineers on where the external box goes?
Just had the front of the house worked on and don't want cables all over it really.
Message posted on 31 Oct 2025 02:51 AM
Re: Fibre install question
@CarelessCoder Where does your current line enter the property? Is the attic a proper room? Does your line come in at the attic or downstairs? Openreach will normally run the fibre to the same entry point, at least they did with my installation.
It should be noted they won't do anything that becomes complex installation wise due to time constraints.
Message posted on 31 Oct 2025 07:46 AM
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 31 Oct 2025 11:53 AM
Thanks, here is the image https://postimg.cc/n91ppN8T
When I spoke to the Sky sales person they did say if the location of the kit isn't what you expected then reject it.
My phone line comes into the front of the house, through the living room and under my stairs. I run a cable from the consumer unit to the attic behind the walls.
I could run a fibre cable from the same point under the stair to the attic but will be some work to hide the cable under floor boards etc.
Yes attic is a proper room.
thanks for the help all; trying to figure out I've I'm asking too much 😄
Message posted on 26 Nov 2025 06:12 PM
The open reach fitter called for a lift as the pole needed it; he took the cable into the side of the top of the house, drilled a hole through almost 1m of wall and set up all kit internally in the attic room.
They were outstanding and the work was very neat! Much better than other fitters for another company; some neighbours have cables up and down their house!
Message posted on 26 Nov 2025 06:37 PM
@CarelessCoder Great the way it needs to be done, as long as it's inside the few hours to get it all done and dusted, and safety is the priority and you are the happy camper then it's good news all round!👍👍
