Discussion topic: Fibre 500 - Ping terrible
Message posted on 05 Dec 2024 01:06 AM
Can anyone help with this please. I have recently upgraded to Sky Fibre 500 only
for my daughter as she is a gamer. However there is zero difference for her with the old broadband to this one, ping terrible. There are only 2 of us in the house so multiple items not being
connected at the same time. Has anyone else experienced this and if so is there a fix as I am not paying the higher premium for something that states is excellent for gaming but clearly isn't. Thanks
Message posted on 05 Dec 2024 07:13 AM
Re: Fibre 500 - Ping terrible
@Sarahc668_ can you post details of the average latency times you are seeing, how these are being measured and most importantly ehether the device is using wifi or ethernet cables to connect?
WiFi in the home is by far the most likely cause of higher latency and poor game play as it is affected by interference which causes higher jitter which is why keen gamers use Ethernet cables wherever possible.
Message posted on 27 Dec 2024 05:04 AM
Consider changing the router that was provided by sky to your own one. The router provided by sky is using wifi5 which was released in 2014 🥲
