5
This discussion topic has been answered Discussion topic: Configuring Sky Superfast FTTC > TP Link TD-W9970 (modem only mode) > ASUS TUF AX3000 V2
This message was authored by: stevenayers
I’m unable to get FTTP until next year, but I wanted to upgrade my wifi a bit and have a decent router for when I do. I’ve tried following various settings etc but I can’t seem to get my setup to work despite reading that it should. Here is what I’ve done.
Physical Setup:
DSL > DSL port on TP Link TD W-9970
LAN1 Port TP-Link TD W-9970 > WAN port on ASUS TUF AX3000 V2
TP-Link Configuration (Bridge Modem Only Mode):
I followed this guide: https://url.net.au/support/configure-tp-link-w9960-for-bridge-mode-nbn
The only bit I did differently was having the region and time zone to UK and GMT.
ASUS TUF AX3000 Configuration (Mainland UK MER):
I skipped the quick setup and made changes to two pages, by following these left by a Sky customer on Amazon:
Advanced Settings > IPv6: https://m.media-amazon.com/images/I/61o9VUN244L.jpg
Advanced Settings > WAN: https://m.media-amazon.com/images/I/61ozAjX5YEL.jpg
I still get the red internet light on the ASUS router. Am I meant to configure the WAN settings on the TP-Link instead of the ASUS router? I assumed that when I put the TP-Link into bridge mode, it would act just like a dumb translator, and then I’d configure the ISP settings on the ASUS.
Thanks in advance!
This message was authored by: cookiemonsteruk Answer
Re: Configuring Sky Superfast FTTC > TP Link TD-W9970 (modem only mode) > ASUS TUF AX3000 V2
@stevenayers
Try enabling vlan id and set it to 101 on the tp link
Then on the asus enable upnp and change aggressive to normal for query frequency
@stevenayers
Avatar for stevenayers
That's working perfectly, thank you!
This message was authored by: Nicolas009
Amazing. Thanks to both of you. I spent ages looking at various posts to troubleshoot for my new TP Link/Asus combo and these two comments had everything I needed.
This message was authored by: NaveedZ
May i ask the need for UPNP on this setup? what does it do or how does it help? thanks
@NaveedZ
UPnP will automatically set up lan devices using the routers lan UPnP servers so you don't have to manually reserve addresses.
