Discussion topic: Fiber and wifi connection Issues
Message posted on 20 Mar 2025 06:57 AM
Anyone else had a new router whcih can't ge tto all the rooms, were a 1970ies bungalow moved in a few weeks back, we were in a 1880s 5 bed adn had signal in every room, i've only just got signal in my office which is next door to the router, anyone experencing this problems.
Message posted on 20 Mar 2025 07:29 AM
Re: Fiber and wifi connection Issues
@Sparkly not unusual at all as each building has its own issues. 1950s bungalows usually have solid brick internal walls which can block a lot of wifi signal.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 21 Mar 2025 10:52 AM
we have already signed up to sky wifi max, its a small bungalow teh last place was twice the size with solid brick walls. not sure with teh amount you pay I should need to spend any more. Very disappointed with the wifi, when its workig its great, but its constantly dopping out, and wont reconnect.
