Discussion topic: Faulty SR213
Message posted on 08 Jul 2026 02:15 PM
Faulty SR213
I have an intermittent conection issue with either the power cable into my SR213 or a fault in the box itself.
Yesterday I spoke to Sky and asked for a replacement but was told to wait for engineer, (No internet for 2 days).
This morning, a message from Sky saying engineer visit cancelled as I had got the system back online (by wiggling the connections).
Today, I have been on the phone to sky requesting a new SR213 but after being put on hold for some time, the call was ended witout a resolution.
What to do next?
Thanks.
Message posted on 08 Jul 2026 04:45 PM
Re: Faulty SR213
If you have everything working then I doubt Sky will send you a replacement hub unless it fails again for some reason so all you can do is should this happen again is to call them.
