Discussion topic: Factory reset
Message posted on 01 Jun 2024 07:27 AM
Factory reset
Hi I have had to use the factory reset but when I type in the 192 bit in my McAfee block the page from opening how can I get around this
Message posted on 01 Jun 2024 07:34 AM
Re: Factory res
@Trucker987 check the settings in McAfee or simply disable it while you access the Sky hub there is no security risk as the IP address is only accessible from devices on your home network. However re-enable protection once you have set up the hub.
Message posted on 01 Jun 2024 07:44 AM
Re: Factory reset
Sorry have done that still having problems not sure what link to use
Message posted on 01 Jun 2024 07:53 AM
Re: Factory reset
@Trucker987 simoly type 192.168.0.1 into the browser and hit return do not add anything before or after those numbers. That is the IP address of your Sky hub and will open its web interface where I assume you want to change settings from the factory defaults from the reset.
Message posted on 01 Jun 2024 08:08 AM
Re: Factory reset
I never get anything up after the 192 takes me to loads of sites tu use
Message posted on 01 Jun 2024 08:19 AM
Re: Factory reset
Sounds like you are typing it into the search bar . Try typing it in to the address bar
Message posted on 01 Jun 2024 08:25 AM
Re: Factory reset
I have no internet connection through sky I'm having to use my ee dongle I was talked into a factory reset for my hub and now I can't reset anything
Message posted on 01 Jun 2024 08:26 AM
Re: Factory reset
And how do I find that one please
Message posted on 01 Jun 2024 11:24 AM
Re: Factory reset
@Trucker987 still not clear what you are trying to do but you dont need an internet connection to access the hub's interface you simply need your device to be connected to the hub. If you want to reset the hub hold in the reset pin until the power led flashes which takes up to 20 seconds then rdlease the pin.
