Discussion topic: Factory reset
This message was authored by mrep75 This message was authored by: mrep75
Factory reset
Hi all hope you can help.
I'm having issues accessing my sky hub as have lost the login details.
now I've tried to factory reset to no avail, I e follow instruction according to sky ( press reset for ten seconds until power light flashes)  is there some thing I'm missing/doing wrong.
any help would be most appreciated..
This message was authored by Kenny+Rankin This message was authored by: Kenny+Rankin
Re: Factory reset
The default login is 'admin' but you need the original password - it should be on the label on underside of the hub
—————————————————————————————————-Sky Stream, Sky Gigafast Broadband with SR203 Hub
mrep75
Re: Factory reset
Thanks for the quick reply.
The default login details where changed and its been a while since I've logged in and stupidly have lost the new login details
hence trying to factory reset the router back to it original settings/admin login details.
doesn't matter what I've tried
the router only seems to be rebooting not resetting
Re: Factory reset
@mrep75Hold the reset button for around 20 secinds and this should set the router back to factory settings.
This message was authored by Eeeps This message was authored by: Eeeps
Re: Factory reset
'Default' means factory default - that is, the password that was set when provided from the 'factory'.
When you do a factory reset all information that you may have changed is lost and everything (should be) reset to how it was when you originally got the router.
Re: Factory reset
@mrep75 a factory reset will definitely return the default log in but in you release the reset pin too early the unit just reboots wait until,the power light flashes which as @Highlinder says can take 20nseconds.
If using an ios device the log in will fail even with the correct details on the first attempt if possible use a non Apple device but if you have to use an ios device try repeatedly and. you will get in eventually.
mrep75
Re: Factory reset
@Highlinder
@Chrisee
many thanks for you responses and sorry for the late reply.
I've held the button 10seconds,20seconds and even 1minute still no joy at the moment,
I will give another go tomorrow...
also Chrisee, yes I realize I'll loose all the settings as they are and usually usually connect the router direct to my laptop rather than use my phone.
again many thanks for all your help.
This message was authored by Chimpybean This message was authored by: Chimpybean
Re: Factory reset
Press and hold the WPS button on the side of the router. Keep it pressed for 20-30 seconds. The led on the front will change colour, flash and, eventually reset back to steady white (about 2 mins).
