Discussion topic: Extra work for sky fibre installation needed.
Message posted on 14 Oct 2025 10:47 AM
Engineer arrived this morning to install my sky fibre broadband but was unable to install because there was no fibre cable running from the outside in. I've been waiting nearly 2 months for broadband in my home to be told they are unable to connect me to the network. In my very first email I was sent,
If you already have an ONT (Optical Network Terminal - a small box which connects the fibre cabling from outside to your Hub), it may need to be replaced during your installation appointment.
The engineer may also need to do some checks outside your home before your installation date. This is all part of the process, and you won't need to be around while these checks are done.
Can anybody help?
Message posted on 14 Oct 2025 11:05 AM
Re: Extra work for sky fibre installation needed.
@BigChefSteve Failed at all the hurdles and it can/does happen as you have now found out, your installation was it OR that came to install it all for you, a contractor or sky Engineer, it will be reported back now to the state off play and what is going to be required to be done! Does not help you but do watch out for the please contact us text/e-mail from sky and go from there onwards!
Message posted on 25 Oct 2025 10:15 AM
BT engineers have been 5 or 6 times to connect full fibre but the Sky Cables are in the road not the pavement and they say they are unable to complete without council approval.
The current Sky cable comes in from the pavement but is surface mounted on the inside of our boundary fence and engineers say they cannot do it that way with the fibre ?
Message posted on 25 Oct 2025 10:25 AM - last edited: 25 Oct 2025 10:26 AM
@PhilNB That will be correct, underground or well overhead are the two options! All cables are OR for the infrastructure, nothing to do with sky!
Message posted on 25 Oct 2025 10:27 AM - last edited: 25 Oct 2025 10:37 AM
Presumably those are Openreach cables: they certainly don't belong to Sky. The only 'Sky cables' are between a satellite dish and a Sky television box.
Putting copper along a fenceline was always a nasty bodge, and just not permitted for an optical fibre circuit (which has zero tolerance to being stretched)
