Discussion topic: External ONT box cover broken
This message was authored by: Evrim1
Hi,
I've had sky broadband installed recently. The engineer appears to have either broken the external ONT box cover or simply forgotten to secure  it shut  properly , either way the cables are exposed to the elements of the weather. I tried to tape the box back until something can be done but with the high winds it keeps falling off. I can't see any screws on the ground . I can't get through to a real person with Sky. What should I do please ?
Re: External ONT box cover broken
@Evrim1
For clarity, the external enclosure is the CSP (Customer Service Point)
It's the internal powered box which is the Optical Network Terminal.
Avatar for Evrim1
Level 0 icon
Oh ok thank you :). I am not very technical sorry😬. The box the engineer put a live line for the phone connection  ( he said something along the way) is open which is outside the house . It's brown in colour if that helps.
