Discussion topic: Ethernet suddenly not working from sky hub
This message was authored by Jeffers-46049 This message was authored by: Jeffers-46049
I am using Ethernet via TP link to other parts of the house, suddenly stopped working, showing self-assigned ip address and will not now connect using Ethernet
This message was authored by Addie15 This message was authored by: Addie15
Re: Ethernet suddenly not working from sky hub
Posted by a Sky employee
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
This message was authored by CraigH16 This message was authored by: CraigH16
I am also experiencing this issue, first saw it yesterday. Reinstalling/restarting ethernet drivers on my desktop did nothing, PC is getting a 'DHCP server not found' message.
@Addie15 please could you support in escalating this issue for me?
@CraigH16 jnfortunately the esclation team are not working today. If you are using powerline adapters in the ethernet connection they are the most likely cause of a lost connection rsther than the hub or your PC try unplugging those and rdbooting them.
@Chrisee thanks for replying, I have re-synced the TP link extenders twice and have all 3 lights showing, so no issues on that side. The sky hub shows my desktop under 'connected devices' and the IP address matches on the hub and in ipconfig.
The exact same setup was working no problem last Thursday, so I'm not sure if there's been some kind of firmware update on the router in that time that has impacted the ability to connect to the DHCP server via powerline.
@CraigH16 Sky freeze firmware over the Christmas holiday so thst is not a likely reason. Personally I would not rule out the speed reduction  is down the powerline units in y experience you can get speed reductions but otherwise it is quite strange. Is it possible to test the hub and PC without the powerline kit to rule thst out?
